Building Integrity
Date:  11-26-2017
Number of Hours:  3.00
Manual Reference:  Section 2
Brief Description:  Air box emergency air flap
In the rare and unfortunate event that FOD or an animal were to completely block the air intake for the engine, a relief flap must open and allow a source of air that is at least sufficient for safe flight until you can land the airplane. Being inspired by James Redmon on this one, I designed a small flap that was riveted to the box on one side and held shut on the other using rare earth magnets. The plate I used on the back was a simple 2 ply carbon layup bonded to the cutout that I had removed. The rivet job was a real hack as I first tried to use nutplates for screws instead of rivets. I eventually decided to just make it permanenet and used 3 rivets to do so. The flap works great but I'll need to test it with the engine running in order to ensure it will work in a real life emergency. Those magnets are pretty strong. One step closer to install on the firewall!
location of flap measured out
flap cutout and riveted on
magnets work great!
magnets work great!
