Brief Description: Oil Cooler plenum gets BID and Micro
The new plenum is awesome. The is great clearance all around for the massive 18 row cooler that again more than doubles my previous cooler. The plenum was superglued in place to ensure the right postion, then 2 plies bid was layed up on the outside, and 1 ply on the inside. After cure, the inside and out got micro for a smooth transition. This plenum will be getting a round of hammered paint as will the rest of the firewall and spar for a more clean and consistent look. I also took this time to remove several firewall accessory bolts and fill in holes that are no longer needed. The new firewall will be polished to give a really nice show quality look. I'm excited!
