The front 2 cylinders, (5/6) have always ran cold due to being in the direct line of air coming through the scoops. I've tried closing off the front of the plenum several times to balance the CHT's but now that I'm finally getting these 2 up to temp, the others are getting too warm. I am currently at a mere 6sq. in. per side. I've decided to try a difference approach. For this idea I covered the front side of both cylinders with Duct tape and 2 plies BID. After cure I'll trim them up and see if this alone will help balance the temps as I'm sure it will. The trick will be to trim them just enough to match the other 4 cylinders. I plan to RTV them to the cylinder fins with high temp RTV. We'll see how this goes :)
