The final 2 inside plies of UNI are layed up. After cure I'll be able to lay down some nice wet micro and begin finishing the inside of this scoop for smooth airflow. I will then need to figure out how to install it to the NACA and provide smooth transition. this may require another cut on the scoop to access the transition area. Then to re-attach it and hopefully smooth out the new cut line micro. hmm. lots of thinking... :)
