Building Integrity
Date:  1-21-2016
Number of Hours:  1.00
Manual Reference:  Section 2
Brief Description:  Balancing the CHT's
So Far, I've been able to get each bank of cylinders within 11 degrees of each other and a max spread of 25 degrees on all 6. I want to see the max spread to withink 10 degrees total if possible. I added a small 1/2" triangle of carbon to the coolest plenum and removed the same amount from the warmer plenum in attempt to balance them a bit. we will see how this does on the next test flight.
block it up just a bit more
