Building Integrity
Date: 9-17-2015
Number of Hours: 2.00
Manual Reference: Section 2
Brief Description: Oil cooler Install and a bad day
I decided, now that final primer was on the bird, I could install this new Oil cooler and plenum business. I began by spreading a thin layer of Red RTV under the cooler attach tabs for a nice airtight seal. I Then placed the cooler in position, and was easily able to reach all 6 bolts using a socket wrench. Yes! After tightening them all down, I injected a bead of RTV along the sides and anywhere else there was a visible void. Accessing the left side wasn't fun due to the fuel line fitting, but it worked out with some effort. Now here is when crap happened. I bought aluminum fittings for my oil cooler even though I knew it was better to buy the SS ones. But at 1/3rd the cost and seeing a lot of other installs, I took a chance. Well, the first fitting went in great. 2 turns past finger tight and done. The second one however got VERY difficult to turn, too early on. At the point where I was using excessive effort I decided to abort and back out the fitting. When I finally got it out I noticed that the threads were completely stripped. DANG!!! The cooler threads weren't as bad, thank God, but I can't afford to have this happen again. The next fitting will be brand new and aluminum as well, but at the FIRST sign of problems, I'll remove both fittings and install 2 SS instead. I'd hate to ruin the cooler to the point where I have to remove it and send it back for repair. Things kind of small problems cause major setbacks and are, by definition, the things that burden every builder. I was hoping to install the oil lines and fill her with fresh oil, but it will have to wait till next week....ugh.
oil cooler and plenum installed
RTV filling the gaps
1 ruined Oil Fitting...:(
