Building Integrity
Date:  7-7-2015
Number of Hours:  5.00
Manual Reference:  Section 2
Brief Description:  Firewall PITA and RTV
When tools break, and bits get dull, you can either stop what your doing, clean up, head to the store and spend God knows how much to replace em, or you can "use a bigger hammer." and get it done ugly. Well, I was not in the mood to spend money or stop working so I chose the later of the 2. In the end, the firewall looks a little beat up, the Plastic inserts are bonded in a little sideways and there's enough RTV to keep a california forest fire out. But gosh dang it, it's done!
All the wires were routed and re-installed then zip tied up in prep for the Naca duct installation. I also installed the regulator inside where she will stay forever I hope.
I went home with SS shards in my knees and decided to add the micro to the naca duct in prep for Primer. I don't want to spend any time underneath this bird if I don't have to. Boy a 95 degree garage kicks off that west systems REALLY Fast. I like it!
It'll work
It'll work
Regulator inside
Regulator inside
Micro on Naca
Micro on Naca
