Building Integrity
Date:  2-7-2015
Manual Reference:  Section 2
Brief Description:  New Injectors, round...who knows
Interesting day. UL Power showed up today to install all new injectors (new type) to try and find the reason behind my engine stuttering on throttle up. After replacing the injectors and TPS, the conclusion is that the engine is running too rich and causing it to load up. This is an issue that relates directly to the ECU tune being done improperly by UL Power. They admittedly did not tune in on a Dyno as they ussually do. The engine however now runs better with the new injectors and will be flown until I get to Texas and can remove the Pipes and ECU and send it back to Belgium for a more precise tuning. It's unfortunate, but it's one of those things you learn along the way when being involved with a "first in type" kind of install. Now, to see if oil temps will drop in flight.
Ready for another test flight
