Building Integrity
Date:  9-18-2014
Number of Hours:  1.00
Manual Reference:  Section 2
Brief Description:  Pipe bracket idea round 2
Each exhaust pipe has an elbow joint that keeps the vibrations from breaking the exhaust off at the block. However, this also means loosy goosy pipes. They MUST be secured so my A&P came up with a good low cost idea that will need a little more engineering to work but is looking really nice. each clamp will be safety wired in between each pipe creating a needed gap between the pipes and also locking down the clamp in a way that will keep them solid enough but not too much. We ALMOST have it right, but I'll need to pick up a couple more clamps that are a bit shorter than these. Should have them finished in time for the first FUEL UP and run on MONDAY!!!!!!!!!
STOKED.
try #1 almost right
try #1 almost right
