I've avoided adding fire sleeve to the fuel return line because it's impossible to slip -6 sleeve over -6 fuel fittings after the line has been assembled...i tried. But as I was cleaning up the engine wires and zip ties I noticed that if the engine shakes enough it may break off the return fuel line at the check valve because I'd zip tied everything so tightly. I decided to remove several zip ties to free up the line, but then there were areas of contact between the braided line and several wires throughout. I decided I could add fire sleeve made for larger line and even though it's not the prettiest install it now solves 2 problems. Both fire and wear are a non issue. The fire sleeve can really take a beating so I'm now much more at peace with this area.
