Building Integrity
Date:  7-26-2014
Number of Hours:  3.50
Manual Reference:  Section 2
Brief Description:  Cooling Plenum #2 begins
To start the day off, I trimmed up the final Carbon Layup for the left cooling plenum and she is now ready for filler and finish work.
I now have a specific path I know to take in the construction process, so the right plenum should take half the time the left one did. I added the foam, tape, and started sanding. In only 3.5 hrs I was able to bring the plenum all the way through the first layer of glass where she will cure overnight. Good times.
Carbon cleaned up.
Carbon cleaned up.
Intake pattern made ez.
sanded down smooth
sanded down smooth
