Brief Description: Oil temp sender woes and Manifold pressure
I started by removing the oil filter to access the area where the oil temp sender is located. I then attempted to add the oil temp sender sent to me from Garmin and found that it was too long and wouldn't fit inside the block. GRR. it then took me 4 HOURS to research senders until I finally found 1 that would work. My gosh. I ordered it along with a few other things I'm going to need here soon. I then installed the Oil Cooler thermostat temporarily until I get the new sender and can finalize that install. Next week there will be a lot of UPS in front of my house :0 Lastly, I installed the Manifold pressure sender. Easy job.
