A design flaw in the engine mount has really made itself known. The tubing that the main bolts go through was short and needed the surrounding tubing to be ground out so that a nut could be threaded onto the bolt. Well this is a bad Idea as it blew through the weld and is now a high stress area. I contacted Richard who made the mount and he is going to extend the tubing another 1" and tack weld it together. He agrees that this should not have happened and is fixing it all at no charge. Good guy to work with.
