Building Integrity
Date:  12-7-2013
Manual Reference:  Section 2
Brief Description:  Contouring the intake and vent lines
I used my DA to sand down all micro for the engine intake inlet. I don't think it can be considered a NACA anymore since I've had to change the shape so much. I then added a lump of micro over the vent lines which later will be turned into an airfoil to reduce drag. On another note I was able to find the COOLEST air filter for my setup. Check it out, FrozenCPU sells a 60mm SS filter for CPU fans and is Super thin. I'm also surpized at how restrictive it is for being so thin as I'm sure it will do a great job at keeping the air clean and will be a snap to clean or replace. The installation of the filter will be detailed in another log coming soon.
contoured the first layer down
airfoil and filler added all over
Air filter screen
Air filter screen
