The intake scoop should be sized well enough to provide adequate airflow to the oil cooler, however it has been demonstrated in the past that adding small "airfoil" pieces to the entry will compress and accelerate the air going through the cooler providing lower temps. I'm game! I used fabulous white foam for this. White foam is flexible but dense. it sands extremely well and cuts easily using a razor blade. I shaped the smaller airfoil much like a GU canard and the the larger airfoil as a stretched version. These went in really well and accepted 1 to 2 plies bid very nicely. I laid them up under peel ply and quick cured them using a heat gun.
