Building Integrity
Date: 5-5-2018
Number of Hours: 6.00
Manual Reference: ch 25
Brief Description: Full Wet sand and detailing
To begin, I got to sand and contour the new urethane primer using 180 grit dry. It didn't cut as fast as I was assuming it would but it was much nicer than sanding epoxy primer. I am tempted to go down to 80 grit next time as I really think this stuff could easily fill those scratches. But the top cowling is now ready for final white primer. I will most likely finish it off using the epoxy primer because it will see UV rays, but the lower cowling will get the new Urethane White primer when it arrives. I then took a sheet of 3M 320 grit, a sponge, and sanded the whole top surface again, getting all the overspray off and last night's round of primer down. Now she was ready for a soap and water bath. After bath time, I jumped inside the cabin and thoroughly cleaned the interior with alcohol and water, carefully avoiding any plexiglass. Boy that stuff cleans! I still have a bit of touch up paint work, which will get my attention tomorrow. I also headed into the engine bay and wiped down everything my eye could see and before I knew it, you couldn't tell I had done so much sanding. A spray bottle of alcohol is a powerful tool :). I also removed the air filter, cleaned out the air box, and filter, then re-installed it all. So it looks like Monday is move day. I still have some small tasks, like making 2 new rudder cables, but I should be ready to hit the airport by Monday afternoon. I will then dedicate the shop space to cowls, wheel pants, the canopy finishing, and prop balancing, most likely taking me through the week until my pipes arrive. And then....she FLIES.
Top cowling sanded down
Bath time
All clean
