Brief Description: 2 more coats of primer and much better this time
Today I went back to using Wax and Grease remover to prep the surface but I still used my microfiber towels. I wanted to isolate the fish eye issue by only making 1 change. It worked perfectly. The Wax and Grease remover is a hands down MUST from now on. After fixing 2 small areas with Z-Grip and sanding her down, I prepped the surface and let her dry for 30 minutes. I then mixed up 1 sprayable quart of white primer which allowed me to shoot 2 nice wet coats all over. A little too wet in some areas as I have some runs I'll have to go back and sand down. No big deal though. This will most likely be the last coat before block sanding her down and spraying one morel run of final primer. The last run will be 3 light coats to avoid runs but obtain build thickness for the last 320 grit wet sanding session. If all goes well, the primer work will be done by this next weekend which means next week, the new firewall install begins :)!!
