Going after every single pin hole takes time, but wet micro makes it easy to fill quickly. After pin hole hunting, I went after larger low spots and voids using a bit more dry micro. this included adding a small radius to the strake/fuselage intersection. I added a nice radius on the top of the fuselage but never took the time to tackle the under side. Well, that's now done and after cure, the whole fuselage will be wet sanded down in prep for another round of primer. My ultimate goal will be to have it in final primer within 3 rounds. Let's see how good I get at filling them holes.
