When temporarily placing the new airbox/scoop on the firewall, I noticed the radius of the leading edge was a lot thicker than the CHT intakes. I want them to match well, so that meant a small change was needed. I removed the layer of glass from the inside of the scoop and sanded down the foam to a much thinner profile. I then laid up 1 ply BID over the foam and micro on top. This will allow a much more matched cross section and should look great! I also added micro to the intake tube and interior to spot fill a few areas. Getting closer!
