Building Integrity
Date:  11-20-2017
Number of Hours:  3.00
Manual Reference:  ch 25
Brief Description:  Air box cover, micro, and primer
I did something Vari bad today. I broke a rule. Shame on me. It all started when I decided to fabricate the air box hatch using a block of blue foam contouring to match the top of the box. The foam contour would create the perfect mold wrapped in duct tape and layed up with 4 plies of alternating BID and UNI. I then sinned.. :) While the Ez Poxy hatch was stil wet I mixed up a batch of West Micro and spread it out on top to avoid a second cure cycle. Worst case scenario it won't cure and I'll sand it all off, but I'm not worried :)
After this I sanded down the oil cooler exit plenum and sprayed on a layer of high build primer that will later be contoured. I want the interior of the cooler to be extremely smooth for good airflow so it may even get a coat of epoxy primer. We'll see. A gel coat would be even better. For now, the primer will allow exposure of imperfections that need to be addressed.
Foam mold for hatch
Foam mold for hatch
grey tape all over
grey tape all over
4 plies glass under micro
