So, the sanding required around the fuel sump is miserable, but has to be done. I'm getting closer to primer on that one. I also had to tackle the final pin holes in the leading edge of the canard using pure west systems. After 320 grit sanding I sprayed a couple coats of paint over the leading edge to verify she is ready for final paint and primer and I'd say we are good to go!
