Brief Description: Wet sanding and spot paint repair
Using primer before paint is a big deal with these birds in order to ensure there hasn't been any poor contouring or pin holes left behind but I got impatient :) I did my best to hunt down the holes, fill em, and then wet sanded the whole thing with a 220grit sanding sponge which worked really well at smoothing the surface without cutting through the paint. Certain areas needed more agressive sanding where the paint was removing, but after spraying 2 coats of paint, the areas are almost undetectable which is awesome. Final paint will be 2 drop coats after all the contouring is complete. This next week, this canard will be back on the bird. :)
