Building Integrity
Date:  1-11-2016
Manual Reference:  ch 25
Brief Description:  Scoop primer round 1 and 2
Having dual 500W heat lamps is a real help when needing to do several rounds of primer like this jobs calls for. I was able to sand down the scoop enough to lay down 2 rounds of primer. The first round was 2 wet coats, then wet sanded after 2 hours under the heat lamps. The second round of primer was also another 2 coats. Brushing on the primer also has the advantage of not using any reducers so the build thickness is great. I'm also using the black primer as it's doing a great job showing me the low and high spots that will be tackled tomorrow with Z-Grip. Heck, I may even use dry micro instead if I have enough cure to lay it on tonight. Either way, grey primer should be here in no time. This setup needs to be flying by Friday.
Ready for primer
Ready for primer
2 coats round 1
2 coats round 1
2 coats round 2.
2 coats round 2.
