Building Integrity
Date:  10-30-2015
Number of Hours:  1.00
Manual Reference:  ch 25
Brief Description:  Paint n primer and a wonderful surprize
When I painted my interior using the Marquee paint I loved so much, I had to buy a gallon of the stuff in the color I wanted as it was an "exterior" paint. Very durable for sure. But I only used a Qt. at that for the whole interior! I went back to do some touch up work and my gallon of paint went bad. GAH! I asked home depot if they made the identical paint in quarts and they said Nope. BUT, they DO, if it's the "interior" blend. hmmm, this being touch up work, I'll sacrifice the durability if the match is perfect. AND IT IS! absolutely a dead on match and sheen to the exterior marquee and only $20 a quart :) I decided to try it on my passenger head rest bulkhead since I made a small change here when I removed the turtle deck naca and I'm extremely pleased. Marquee, I love you.
The second job was to add primer to the top of the turtle deck. I brushed on 3 coats and will sand it down here on Sunday or Monday and most likely spray the final coats. The Micro contouring was almost flawless. Boom!
Interior Marquee is a hit!
3 coats primer on top
