The primer cured perfectly with almost NO orange peel at all. Sick! I sanded the pants to 400 grit then headed to the airport. I checked the new tires and tubes to ensure no leaks and both held steady at 64 PSI overnight. I boosted them to 75 PSI for flight and filled the nose tire to 50 PSI. I then installed the wheel pants and she is now ready to rock n roll for another 60-75 landiings.
