Brief Description: nose hatch install and sanding more
The nose hatch was cleaned up, sanded to 400 grit and prepped for install. The weather stripping was installed on the fuselage side this time for easier replacement someday. The hatch was then installed and I sanded all the final primer areas with 400 grit again. My primer work is now done until its time to wrap this bad boy. The avionics cover will go back on when I have the time to scrape off the old weather seal and replace it with the new D seal I picked up. Hoping it keeps the leaks out better than the original stuff.
