The pics show a few areas that needed a little micro tlc. I made sure to use wet micro around the fuel cap area to ensure the lack of pin holes and gaps. I had a problem with the west systems setting up to quick and even exotherming to the point that it started to smoke!! So I had to use Z-Grip on the last couple spots. Tomorrow I'll be sanding these all down and prepping the airframe for Primer spray. I'm hoping to get primer sprayed on EVERYTHING before the weekend hits so that next week the focus will be block sanding the wings and prepping this thing to look really good once again. :)
