Brief Description: Mo Primer and the cowling goes on!
Alright, so here are 3 great pics showing the addition of todays 2 coats of primer (Brushed on) and the cowling cut out to clear the oil cooler. Of course, the cowl won't be left like this, but it gives a great perspective on the lines that will flow into the cowl. If any of you have ideas for a new lower cowling contour do share!! LOW DRAG Only! Also, I need to incorporate an EXIT for the oil cooler air IF it proves to be needed.
