Building Integrity
Date:  7-24-2015
Number of Hours:  2.50
Manual Reference:  ch 25
Brief Description:  naca Dry fit success and final micro
So after "sleeping on it" I went ahead and added a couple thin flanges to the sides of the Naca duct to better seal off the cooler, affectively minimizing the RED RTV that will be needed for an air-tight seal.
I then took the whole assembly to the airport for a dry fit on the firewall and belly. The fit was 99.9% Perfect! Just a wee bit sanding of the firewall and she will be ready for bonding in place. Knowing this, I took the duct home and ran a bead of micro inside and outside of the newly installed flange. After cure it will be sanded down and this duct will be permanently installed on the aircraft. I'll mention I can already tell that the lines flowing into the cowling will be OH so Sexy. Best lower cowling lines yet... to come!
Small Sealing Flange installed
near perfect fit
near perfect fit
Final Micro on flanges
