Building Integrity
Date:  1-30-2015
Number of Hours:  1.50
Manual Reference:  ch 25
Brief Description:  Canard torque tube seal
Eh not so hot. I intend on finding a solution for the drafty air that comes in and freezes my thighs in flight, however todays work didn't work. I was able to make a template for a foam plug idea I had however the gap between the elevator and fuse is too tight to get anything inside there without removing the canard. I most likely will decide on FINAL paint/wrap/primer before I cover this topic again. the foam I made would bunch up and not make a seal around the perimeter as hoped. I KNOW there IS a solution but this one is on hold...and summer and San Antonio is coming!
beginning
beginning
Not a bad template to start with
