Brief Description: Wet sanding and finishing hardware
I wet sanded with 1500 grit then 3000 which worked pretty good. Surprised how fast the 1500 cut through. Finally gave it a soap and water bath to reveal all the defects that will be perfected over the course of it's next year in flight, and called it good enough for now. I then installed all new finishing washers and #10-32 screws to the control surfaces. I then filled the tanks with fuel and tucked her into bed for the night. 22 gallons total will be good for the first flight. :) only days away
