Well there's nothing like 1 uniform color to expose all the mistakes you didn't see. LOL. Luckily the sanding work was good enough for this round. I was able to lay down 1 coat of hammered black everywhere forward of the panel and 2 coats everywhere aft. This again will only serve as a texture. Funny thing is that this brush on paint takes a full 7 days to cure enough for a topcoat so I'll be moving on to the exterior contour and primer while this cures up real good. In the meantime I need to decide what parts of the interior get almond and what stays black. Choices choices. There may be a couple spots that are bad enough to get a little filler before topcoat which won't be an issue. We'll see. Getting closer!
