Building Integrity
Date:  4-22-2014
Number of Hours:  0.50
Manual Reference:  ch 25
Brief Description:  Avionics cover and gear hardware paint
The first few flights will be made without the wheel pants attached and my pretty primer will be interupted by naked gear legs, soooo I sprayed a single layer of Satin Black on the exposed gear legs which is obviously and completely unnecessary :) I then painted the axle hardware and plates the same satin black along with the avionics cover. The panel cover is now in its final 2 coats of paint that it will fly in. After cure it will get a thin strip of weather seal all the way around.
