So what do you get when you skim coat with epoxy that is slightly infused with micro? MICRO SKIM! In fact it's just like skim coating with slurry and it's absolutely incredible. MY GOSH if I had tried this trick on the wings I'd have a flying airplane by now. CHECK THIS OUT. Picture 1 shows the elvators. The elevator on the left was skim coated with pure epoxy. The elevator on the right with slurry or I call it Micro skim. After block sanding both it was astonishing how much easier it was to sand the slurry and how much more Build I got. In fact I've been able to fill large voids and ALL pinholes with only 2 coats of slurry vs several epoxy coats. I'm SOLD. OH, and no more squeegees, or air bubbles. I just FOAM ROLL it on and it's DONE and NO RUNS!!!!> Check out PIC 3 to see this amazing finish.
Here's the deal. LESS Coats, LIGHTER weight, LESS work, NO pinholes, No air bubbles = MICRO SKIM. DO IT!!!!
Tip; throw your MIXED batch of Micro skim in the microwave for 5-10 seconds for a SUPER easy to roll consistancy.
