Building Integrity
Date:  4-1-2014
Number of Hours:  8.00
Manual Reference:  ch 25
Brief Description:  Micro acne...
Using micro over filler is nice because the difference in color and ease of sanding will make for good contouring after cure. I decided to turn on a good radio show and get at it. It ended up being more of a steady meditation than tedious which helped a lot. focusing on one small area at a time I ended up puting dry micro in every void I could find. This also led to adding another layer along the strakes and longerons. My goal here is to get the surface level enough so that I can go back over it just 1 more time prior to skim coating. With the wings I learned to do EVERYTHING I can to bring the contour where it needs to be PRIOR to skimming as sanding the skim is no fun. I still have to tackle the turtle deck/canopy transition as well as the canard so she will sit here waiting for skim for another week or so.
spot filler
spot filler
micro strakes
micro strakes
micro longerons
micro longerons
