Brief Description: Interior and console prep and micro
I'ts gonna be a LOT easier to properly fill and sand these consoles while they are outside of the airplane rather than installed but I have decided to wait on the paint until the interior is completely finished. I spent a good hour with a sanding sponge and 80 grit sanding the entire inside of the cabin and all of the consoles in prep for micro. I've elected West systems rather than Z-Grip for 2 reasons. 1. I don't need the fast setup time of Z-grip and with enough micro, West systems truly is eaier to sand and contour. However as soon as my interior reaches 145 degrees or more, it's all gonna start getting soft. HOWEVER I plan on taking measures to keep temps from ever getting that high anyways. So I slathered on the micro on all 4 consoles as well as the speed brake actuator cover. After glassing them in I will obviously need to micro the glass weave so I didn't try to get every square inch this time around.
