A few layers of filler sanded down till glass showed up. Contour on the underside of the left Aileron is much better after using the new 36grit straight edge. Still takes a lot of time for a small area. I'm also beginning to wonder how heavy this Z-grip is comparred to the same build thickness as micro. I'm almost positive it's heavier as I've already put 14 oz on the 1 side. Granted the reconstruction of the aileron left high glass spots that were inevitable. But almost a pound on one side is concerning. I'll do some research to see if it changes my mind about Z-grip for the fuselage. I'll have to see a huge difference to switch as This stuff is great to work with.
