2 more coats of epoxy primer were sprayed and after enough cure time to handle I went over the entire wing hunting for any pin holes. In total I think I found 10. I whipped up a little west sytem and skimmed over the holes with a toothpick and putty knife. After block sanding this primer I'm hoping the contour will be good enough to spray the last 2 coats of grey primer that she will fly in.
