Building Integrity
Date:  6-21-2013
Number of Hours:  6.50
Manual Reference:  ch 25
Brief Description:  Fill and Sand from firewall to nose
Today the canopy is on and it was time to bring the fuselage into 1 long streamline contour with filler. I added filler from the firewall to the nose and started sanding. At this point I'm convinced there is NO reason someone should go to the gym if they are building a composite airplane. I've brought the contour to a good general shape, but there are several low areas still. These spots will be filled and the sanding will continue later.
filler all over
filler all over
Sanding has begun
Sanding has begun
FInished for today
FInished for today
