3 hours included sanding and prep for any areas on the canard that needed fill in low spots or exposed foam. 1 batch of micro can go a long way so I found and filled as many spots as possbile including the need for a straight leading edge. The previous builder made one side of it with a slight inward bow so this should straighten things out.... a common theme for this canard...
