The Glass work is finished so now I begin adding micro and contouring to shape. I did find an issue last night, however, that added some work to my list... The previous builder did not make the trailing edges of the tips alike which causes an illusion of twist in the elevators when neutral. This can also cause an unintended roll so I have decided to re-shape the other tips TE to match. Again identical tips is the goal. I added dry micro to the TE that will be shaped and it MAY not work because of the absence of glass that will be exposed. For now I'll let it set up and modify it if needed to give it a rigid edge. Most likely this will require a layer of BID and all will be well.
