The brain box needs to be mounted with piano hinge and magnets. I've decided to start the process by bonding 2 pieces of foam to the floor using x-30 and will create 2 hardpoints inside the foam where the piano hinge will be located. This hinge will allow easy access to the Vertical Power VPX-Pro. more later....
