Brief Description: Passenger consoles trimmed and fitted
Late last night I knife trimmed the consoles and noticed that using saran wrap did help the lifting areas but acted as a peel ply and caused the layup to be excessively wet. I will only be using that technique when absolutely needed. After sanding the consoles fit was great. I am considering making the right console a little narrower if the control system from Cozy Girls allows. With only 15" at the hips, there won't be any larger people in the back unless I can do this. We'll see.
