Brief Description: Glassing the passenger consoles
I pre-pregged the final 2 layer BID for both passenger consoles. The plans suggest using saran wrap on areas that are prone to lifting so I thought I'd try it on one to see the difference after curing. Doing a pre-preg on a layup that is 56" long was no easy task when it came to pulling it off the table and laying it out on the console. I did however find that I could fold it, even after applying epoxy and then unfold it on top of the console with no problems.
