Long Ez: Building a Dream
Date:  4-28-2012
Number of Hours:  4.00
Manual Reference:  ch 24
Brief Description:  Pilot Thigh Support
Before building the Pilots Thigh support I needed to fill and prep the original landing light location as I will be using LED's in the nose or strakes instead.
For my first layup EVER, I did a 1 ply BID on both sides of the support braces. Wanting to keep things clean, I did a Pre-preg inside painters overspray plastic sheets and will hope to see that after they cure I will be able pull them off like peel ply. If not, I'll have to start over and use thicker plastic sheets as these a quite thin.
roughly shaped foam filler
sanded and filled with slurry
My first Layup
My first Layup
