Before building the Pilots Thigh support I needed to fill and prep the original landing light location as I will be using LED's in the nose or strakes instead. For my first layup EVER, I did a 1 ply BID on both sides of the support braces. Wanting to keep things clean, I did a Pre-preg inside painters overspray plastic sheets and will hope to see that after they cure I will be able pull them off like peel ply. If not, I'll have to start over and use thicker plastic sheets as these a quite thin.
