There wasn't a lot of play room for the servo heat shield to be installed but it worked out great. I "may" make a new rudder cable slightly longer than the present one, in order to clear the shield a bit more but we'll see how the shield works first. For now there is no contact so it's airworthy. I did have to re-enforce the shield a bit in the corner using JB Weld due to the vibration this shield will see in that area and want to avoid a crack developing. Sure hope this does the trick.
