Building Integrity
Date: 11-15-2014
Number of Hours: 3.00
Manual Reference: ch 22
Brief Description: Marty to save the day!
It all finally works! In order for 3 guys to wire up an entire airplane in 2 days without any bugs would be a miracle. Well, we got close! After assembling the airplane and firing it all up, there were a couple small issues. #1 The transponder wasn't reporting altitude. #2, the AP Servos had a network error, and #3, the oil temp sensor wasn't working. Well the sensor was wrong and swapped out, which Marty wired up nicely today. That one was my fault. The Transponder had 1 small wire in the wrong pin location, and the AP Pitch servo needed a small jumper. These were overlooked in the 48 hour install madness and VERY honest mistakes. In 3 hours we had everything working, and zip tied, ready to fly. Thanks Marty!! He also, took time to Zip Tie my Oil Pressure sender the way the EAA suggests which will extend the life of the sensor quite a bit.
Now I just have to get my Fuel burn and fuel tanks programmed to read correctly and I'm in Business!
Marty Tidying things up
Nice work!
Vibration proof but ugly
