I did 8 hours today but it felt like I should have got more done. I started by assembling the passenger power panel and adding weather stripping for a better all around seal. The USB charging port and Heated seat controls were installed and now I am waiting on the audio jacks and plugs which will come Sat. I repeated this process for the pilot panel as well. A little PIA that happened was a couple nuts pulled out from the hard point locations and needed to be bonded back in place. They are now fixed and ready for final mounting. I next decided to butt splice the Nose gear power and ground and route the wires using adels. I then added adels for a path to the landing light, however this needs Molex plugs so it will have to wait till Sat. for completion.
