Brief Description: Switch wires, speed brake and cleanup
Over 10 hours to wire the speed brake, all the panel switches and comb through the wires. I tightened up every path with temporary zip ties that will be replaced with permanent ones or nylon strand when absolutely everything is finished inside this beast. All of the D-Sub connections I left alone for Harrison Avionics to do when they arrive on Saturday. Only a few more power and ground wires are left to run along with the EIS Data lines so Saturday shouldn't feel too rushed. I will be doing everything I can on my end before they arrive. Stay tuned!
